G
Gherkin
I've been using LE for a while now, and the lack of automatic delay compensation had never been an issue...
BUT, now I'm wanting to use some outboard gear, and use the 'hardware insert' function, and the delay is annoying the hell out of me. It can't even calculate the delay like it says it should.
It says there's a 6 sample delay on a track with a hardware insert, but after much playing around, it's actually about 3365 samples.
Is there a plugin around that can calculate the delay of a track and automatically compensate? Is there a plugin around that will do the opposite of delay? (As in, play the track slightly early)
What do you guys do about this issue?
It says there's a 6 sample delay on a track with a hardware insert, but after much playing around, it's actually about 3365 samples.Is there a plugin around that can calculate the delay of a track and automatically compensate? Is there a plugin around that will do the opposite of delay? (As in, play the track slightly early)
