Plug Ins Not Showing Up On PT!
  • Thread starter Thread starter P Stew
P
P Stew
I installed a bunch of new plug ins. But there not appearing when i go to look through my effects. Is there a certain folder i need to put things? ? any help?
Izotope, Antares Kantos, Waves and more. I've installed other waves plug ins before and they still work. They just showed up next time i ran Pro Tools after i had installed them. Im lost.
PPC or INTEL
Did you install them or copy them to the folder?
If you copied them to the folder check to see if they are PowerPC or Intel?
It's not unheard of to have a bad install.
It is however unheard of to have multiple installs of multiple manufactures off of multiple install disks fail. The likelihood is at best astronomical.
Were these newly purchase pieces of software?? Are they all compatible with both your current version of PT and operating system?
Have you tried looking in your plug-in folder? Have you tried un-install from the original install disk?
Let's drop back and punt here.
Describe the exact process you followed installing the Antares Plug-in. Was it installed from an Antares install disk?
For the waves did you run it from disc or from an .exe? and what was the name of the file you ran to install it?
also what version of pro tools?
Are they vst or rtas. Mac or windows OS. Are you running a mac, you need to wrap vst plug-ins using a program. If this applies, let me know and I'll go deeper into it.
im having the same issue
the plug ins were free downloads by the way,,call off the hounds:D
Still in all. The information provided (at least up until this point) was sketchy, if that.
Cracked plug-ins not withstanding is extremely difficult to help with tech support situations with virtually no provided information.
What free downloads are we talking about? What is you application version? What computer and OS are you using? Describe, in some small detail, the phrase "I'm having the same issue"
Love to help but a guess at this point would be no more than irresponsible.
hi Joseph
ah well,,now
i was on a free plug ins mission that day,so there were a bunch of them
did i already mention how crap i am at all this?:o
im even none the wiser wether or not it should be vst/au,,etc that i download
such is my ignorance
the last one was Voxengo Elephant, which it appears is vst
im using a 1.83 ghz Intel Core Duo Mac Mini
my pt version is 7.1.1
System Version: Mac OS X 10.4.11 (8S2167)
if that helps in any way at all
i see all of these in the Digidesign Plug Ins Alias folder
i know some of them are pre installed, but any of the others(apart from Amplitube/Gearbox) dont show up
AmpliTube2.dpm
BF Essential Clip Remover.dpm
BF Essential Corr.dpm
BF Essential Meter.dpm
BF Essential Noise.dpm
BF Essential Tuner.dpm
BitterSweetII.dpm
blockfish.vst
bombfactory 1176.dpm
bombfactory BF-3A
bombfactory BF76.dpm
Broadband Noise Reduction LE
Chorus.dpm
Click.dpm
Cosmonaut Voice
CrayonFilter.component
CrayonFilter.vst
Crazy Ivan.component
Crunchessor.vst
D-Verb.dpm
daHornet.component
daHornet.vst
DigiReWire.dpm
Dither.dpm
Dynamics II.dpm
Dynamics III.dpm
Elephant.vst
endorphin.dll
EQ II.dpm
EQ III.dpm
Flanger.dpm
floorfish.vst
Funk Logic Masterer.dpm
GearBox.dpm
GetablitchJRUB.vst
Invert-Duplicate.dpm
JOEMEEK Compressor
JOEMEEK Meequalizer
L2007 Mastering Limiter.dpm
Line 6
LoopAZoid
Massey CT4.dpm
Maxim
mda Bandisto.vst
mda BeatBox.vst
mda Combo.vst
mda De-ess.vst
mda Degrade.vst
mda Delay.vst
mda Detune.vst
mda Dither.vst
mda DubDelay.vst
mda DX10.vst
mda Dynamics.vst
mda ePiano.vst
mda Image.vst
mda JX10.vst
mda Leslie.vst
mda Limiter.vst
mda Looplex.vst
mda Loudness.vst
mda MultiBand.vst
mda Overdrive.vst
mda Piano.vst
mda RePsycho!.vst
mda RezFilter.vst
mda RingMod.vst
mda RoundPan.vst
mda Shepard.vst
mda Splitter.vst
mda Stereo.vst
mda SubBass.vst
mda Talkbox.vst
mda TestTone.vst
mda ThruZero.vst
mda Tracker.vst
mda VocInput.vst
mda Vocoder.vst
mda.component
Mod Delay II.dpm
MonstaChorus.component
MonstaChorus.vst
moogerfooger Delay
moogerfooger Ringmod
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Overtone GEQ.vst
Ping-Pong Delay.dpm
Reverse-DC Removal.dpm
SansAmp PSA-1
Signal Generator.dpm
Sound Delay.vst
spitfish.vst
STTool.dpm
Tape-Head.dpm
Tel-Ray Delay
Time Comp-Exp-Pitch Shift.dpm
TimeAdjuster.dpm
Trim.dpm
VariSaturator.vst
VocALignLEX
Voce Chorus Vibrato
Voce Spin
vt3.dpm
There are a lot of VST plugins there.
Pro Tools doesn't support VST which would explain why they aren't working.
cheers PEZ
thats one thing ive learned then!
thanks mate;-)
any idea how id get any of the other type to show up in PT?:o
What are the ones that don't show up, and what was the method you installed them by? I.e what was the name of the install file
