Just to make it easier on everyone, see below lol
Product Description
The Fast Track Pro delivers all the mobile recording flexibility of
the Fast Track USB, plus even more professional features. You get 2 front-panel mic/line inputs complete with phantom power for condenser microphones, inserts for outboard effects balanced and unbalanced analog outputs, S/PDIF digital I/O, MIDI I/O, and more. Fast Track Pro also features near-zero latency direct hardware monitoring and low-latency ASIO software monitoring, plus an A/B source switch and dual output pairs for DJ-style cueing. Fast Track Pro is compatible with most popular PC and Mac music software. USB connection and bus power along with class compliancy for Mac OS X* make it a breeze to set up.
* Class compliancy supports up to 16-bit/48kHz 2 x 4 operation on OS X 10.3.9 and higher. Driver installation required to access more I/O.
Technical Description
24-bit/96kHz audio interface
2 front panel mic/instrument preamp inputs (Neutrik XLR/ 1/4 in. TRS) with:
-gain controls
-signal/peak lights
-pads for each input
-insert jack (1/4 in. TRS) for outboard processors
2 balanced outputs (1/4 in. TRS)
4 unbalanced outputs (RCA)
S/PDIF coaxial I/O with w/ 2-channel PCM
S/PDIF out also supports pass-through of AC-3/DTS surround-encoded content
1 x 1 MIDI I/O with activity LEDs
headphone output (1/4 in. TRS) with level control
headphone A/B source switch for DJ-style cueing
input/playback mix control for hardware direct monitoring
mono switch for input/playback direct monitoring
master output level control
near zero-latency hardware direct monitoring
USB connection to computer
powered via USB or optional AC power adapter
Kensington lock port
Mac and PC compatible; class compliant with Mac OS X 10.3.9 and higher
up to 16-bit/48kHz 2 x 4 operation is class-compliant. Driver installation required to access more I/O.
Compatibility:
WDM
ASIO 2
Core Audio
