M
MITCHM2005
Hey guys, I need serious mojo and advice...
I've got the following external equipment:
(1) Behringer Headphone amp (HA4600/Power Play Pro)
(1) Behringer Virtualizer Pro (DSP2024P)
(1) Samson Stereo [Compressor/Limiter/Expander/Gate] (S Com Plus)
(1) dbx Provocal [mic pre/tube emulator]
(1) TC Helicon Voiceworks [Harmony/Correction/Effects processor]
Last week, thinking that it would be easier to invest in a patchbay, instead of going behind my external equipment all the time, and hardwiring it from the external equipment to the 16G, went out and bought a Neutrik Patchbay (NYS-SPP-L1), thinking that would be much more flexible.
When I came home, I was expecting the instruction manual to be easy to follow installing a patchbay, what turns out to be, is that I have no idea on how to connect all my external equipment that I have to the patchbay.
What I really need is someone to please walk me through making the proper connections from the 16G to the patchbay to my external equipment.
I understand the front of the patchbay has 2 rows, 24 connectors each..
so the top row has 24, and the bottom row has 24...the top row is labled A..and the top row is labled B.
According to the documents and info that I have been reading for a week now, the top front row is usually used for outputs, while the bottom front row is usually used for inputs.
When I look at the rear of the patchbay, i'm totally lost,
cause it shows the same exact layout, as the front of that patchbay,
I have no idea if the rears are outputs only, or inputs & outputs.
Would anybody please have time to reply back and offer advice on the best way to connect an external patchbay to the 16G and then to my various external equipment?
Thank you so very much for help in advance, this forums a great place to be.
