PLease explain D.C. offset
  • Thread starter Thread starter crazyhorse
Status
Not open for further replies.
C
crazyhorse
I think I know what it is. I've noticed that even simple reverb, e.q., freq. filtering, etc. will often offset a properly zero'd wav. If this is true then should't I be Running a D.C. Offset adjustment after every processing procedure?
If you're not sure you know what it is, do a search because we've talked about it here many times. Since it should only happen when recording, you should only have to fix it once, after the WAV is created. Sounds like you're having hardware problems though. Does your house have properly grounded wiring, or are you using a SoundBlaster card?
[This message has been edited by Dragon (edited 01-03-2000).]
Status
