Bad news: I have a very small budget. As in, as small as I can possibly get to get something decent.
Good news: My dad works for Owens Corning. Which means I have access to discount rates on OC 703 XD
Okay, so i've got a nice square box here. I've got a small waterbed with its side pushed against the window. Where the bed ends I want the vocal booth to begin. It'll be about 6x6ft. I'm thinking of creating a sort of "door frame" mechanism, but I'm not sure if it will work. Basically a row of 3 door frames or so, with no door, but instead foam insulation filling the doorframes, with a comforter or something on one end. My thought was to get OC 703 and fill up the door frames with it somehow, then attack foam to it, with a comforter on one side.
My questions...
1) Should it be rounded, until the walls where it goes to the corner of the room? Or just a triangle?
3) What should I do to the dry wall corner?
4) Which way should the singer face? Using a tube condensor or cardoid condensor?
5) What goes above the booth?
6) Will this work?
My questions...
6) Will this work?
