Pilots wanted!
  • Thread starter Thread starter Dr ZEE
Dr ZEE
Dr ZEE
Anti-Pro Circles Insider
Any pilots in the joint tonight? :D
What THIS THING is good for. What does it do? What kind of amp can make out of it :D ? Any idea what's inside?
thanks a bunch :)
Well, apparently, as per the revised description, "These radios were used to signal aircraft when their own aircraft went down in the water. It was copied from the German WW II Not Sender Gerate. There should be a kite with it as well as baloons and hydrogen generators." :eek:
Daniel, thanks for swinging over it. This is a one freaky item :). I want to know what's inside. hmm, gonna watch it. see how it goes. :D
A 5 or 6-watt radio transmitter. You could go wireless, Mike. Only problem is it transmits on 500 kHz, an international distress frequency... but that might be appropriate considering the current state of popular music. :D
Also has a kite, balloons, a hand-crank generator, batteries and a long wire antenna. Sounds kind of a ham radio piñata sort of thang. ;)
http://www.thekitesociety.org.uk/Gibson Girl.PDF
Ah! Cool, Tim! Thanks a ton for the pdf.
Now that is a fancy gadget.
Sooooooo... hmm, say I'd get this thing. Get it on the bench, start doing "my thing" with it ..heh heh, and somehow activate it. So, then, I suppose, I'll be rescued rather soon :D :D :D LOL
