sjoko2
xtremedb said:Sorry, I’m not buying it. That explanation may work fine in a textbook, but in the real world, it is *never* that easy. For one thing, there are always placement constraints. On the underside of a snare, sometimes, you’re lucky to fit a mic at all, much less have the liberty to measure how far out of phase the wave is and move the mic accordingly. There are lots of similar situations where this is the case. As I mentioned in my previous post, the stuff you buy from the store will often arrive wired out of phase to begin with. Are you supposed to move the mic all over the place, just because they can’t conform to the iso standard?
- Be it live, or in a studio, I have never, ever, not found a space to put a mic under a snare, from large condensers to 57's to, now, small clip-ons, there is plenty of space? As a matter of fact, nine out of ten times I use another mic as well in the same general area, to capture the kick hammer attack.
- No, you don't have to move a mic all over the place under a snare to correct phase. The waves of the predomimnant frequencies a snare transmits are relatively short, movement between in- and out of phase is therefore small.
- If you find that stuff you buy arrives wired out of phase, may I suggest you return it? Or, as I have done for the last 35 years, always make your own wiring. Whatever you do, you don't work with faulty equipment.
If you don’t have a phase switch on your console, I admit it makes things a little tougher. If you don’t want to change cables, they build adapters, which are basically metal tubes with out of phase contacts. Just plug it in before the board and listen for the low end. That’s a hell of a lot faster than moving the mics around and guessing. Once you’re at least in the same ballpark, you can work on placement.
- In my opinion faster is not the way to go about microphone placement. Apart from that - you advocate checking phase, and reversing phase if you find a mic to be out of phase, and THEN work on placement? Why? So you can move them out of phase again?
If the cable was wired out of phase to begin with and you move the mic to correct for this, you may create another problem. For instance, now you might now really be picking up the ride etc. Where has that gotten you? Nowhere.
-Why do you assume that everyone works with faulty equipment as a matter of cause? If that was the case, ever single post in this forum should end with "it might not work 'coz you've got a good chance your gear is fucked"
BTW reversing the phase on the underside of a snare is *not* done for effect. It is simply good sound engineering. This is a common phase problem, as is reversing the phase on an open back cabinet, when using both front and back mic’ing.
- How can I explain this one? When I said I often have one in- and one out of phase microphone on a snare drum, I actually ment .... exactly what I said. For effect, for sound, not to correct a phasing problem, because I didn't have a phasing problem, because I place my microphones correctly, and because I use cables that are wired right. Now THAT IS simply good sound engineering.
One further point. This is a site for home recording and today a vast number of homers use DAW's. One of their pleasant features? An editing window. You can see the waveform, you can see if something is in phase or not, you can even ascertain if you have a phasing problem which floats between frequencies. That is if you want to see it, normally your ears should tell if you have a problem or not.
Does that help Brad?
Sjoko (an unfrustrated, not running 'round in circles person with in-phase gear)
I still don't see the advantage of the visual representation of phasing.
