Can an AKG C3000B run on 48v or does it need 52v? If it needs a 52v supply where can I get a cheap one?
Thanks
Adam
Thanks
Adam
That's right, MrZekeMan. "Electrets" don't need phantom power to charge the capsule - the capsule has the charge built in. They DO use the phantom power to steal a few volts to run the electronics.MrZekeMan said:I think it's only the electret type mics that can use the variable voltages. I think the standard condensors usually require 48v power. Is that correct Harvey?
Taylor
