Marik
Pro Microphone Design
Larry,
I used some of Pelusos capsules and would agree with you that he makes them well.
I found a few things in your message, which are not clear to me, or I would respectfully disagree:
>A GE 6072 (12AY7) Black Plate tube will help most of the C12 design microphones, like the MXL V77. The V77 uses a single diaphram capsule unlike a C12, but the electronics are simular.<
V77 has a center terminated capsule (Neumann style) vs. C12, which is an edge terminated (AKG style). Also, both microphones uses completely different way of biasing the tube. My question is how MXL V77 is a C12 design?
>Put a Peluso capsule in it, double the size of the output capacitor and it makes one fine microphone.<
I could argue here. Stock capsule in fact is not that bad. Properly tuned it can sound very good. Double sized (I think you mean its value) cap. even of very good quality won't change much either, as the main problem IMHO is the output transformer. Without rebuilding it with better lamination, or changing it with something better, replacing stock capsule with Peluso's one would not be justified.
>(The Telefunken and Mullards are good in amps but are too soft in a microphone to cut in the mix, in comparison with the black plate tubes)<
I am wondering what do you mean by "soft"? And what is so special about blackplate tubes, as a family?
>Sylvania tubes, as a whole, have more gain than any other...<
>If you have a 12AX7 tube, you can change it to any 12A_7 (or their industrial number) and you wont hurt anything. Keep changing it until you can say "that sounds a little better."<
The 12AX7 is the highest gain tube in a 12A_7 family, so first of all, replacing it with others, you will lose gain. Also, 12AT7 and especially 12AU7 need different operating points to work and sound right. For microphone application IMHO 12AX7 is not good at all, and I would agree that 6072 would work much better here. My personal preference is a GE 6072 5 star.
