Farview
Correct. If you have both analog and digital meters, set the level on the analog side and glance at the digital meters to make sure you aren't clipping. That's all there is to it.Right about the average to peak....though I still say it's the analog levels you need to set correctly...NOT digital levels. If you match the right reference (-10/+4) on both your analog front and your A/D converter...then set the levels at your analog front for good gain and good sound...the digital level really takes care of itself.
My converters don't even have the ability for input level adjustment...the input level at the converter is set by the analog front end output.
If you don't have analog meters, you just have to play the guessing game with the digital ones. What I do is set the level of a sustained note at around -18dbfs and then just make sure that it doesn't clip. For drums, I just set the peak around -6dbfs and call it a day.
