A
absintheparty
Okay so I'm sorry if this is may be a simple question or may be confusing, but I'm right now using a PreSonus Digimax FS preamp that I connect via light pipe to a ProjectMix I/O so i have more pre's to work with (even though the projectmix pre's are terrible IMO) and I wanted to create a patchbay with some outboard gear I have, however I'm slightly puzzle how to do so properly
On the back of the Digimax, it has sends for FX as well as direct outputs and DAC outputs. To my knowledge I would simply route the DAC outputs to my jack field as well as the sends, that way I could patch in effects (even though it would all be pre-fader? Essentially?), and I'm assuming this would still send my final signal (patched or not) through the light pipe into my ProjectMix. So my first question is, is that the correct way to go about this?
My next question, assuming the above is correct, is that if I were to do that very set up, would that require me to always have to have something patched otherwise my signal flow would not go through to my light pipe then output, or would my signal always flow to my lightpipe/outputs/projectmix but allow me to simply plug in an effect if necessary? Otherwise how would I go about already having my signal flow without patching (unless I'd like to patch whatever FX I have) and not have to patch my In's to Out's every time? I know this has to do with normaling and half normaling but I can't say I am the best with it and still trying to fully understand it.
Thanks in advance for the help
