D
Dr.Cool
I was wondering if anyone would fill me in on the benefits and disadvantageous qualities of each pertaining to monitors.
If an active speaker is driven too hard, starts to smoke and possibly catch fire... is it like a 1000 times more dangerous because it's plugged into the mains??
Fact is that MOST, if not ALL, active monitors are underpowered, this is why they need to have a clip indicator....lol!Ironklad Audio said:active monitors should never do that, because the amps are perfectly matched(at least should be!) to the drivers...you would essentially have to be a complete dumbass, ignore the clip indicators, and well....yea....be a total dumbass, in order to cause that sort of damage
Poor design.Cazzbar said:That's what I'm still a little confused about, my active speakers have a built in limiter (as well as thermal, DC fault and short circuit protection) so why did one smoke like a chimney?I know I was sending too hot a signal to the speakers as the clip lights on my mixer were flashing, but my DBX compressor doesn't smoke when I'm using that as a limiter (the speaker did survive the night though and is still working)
TheDewd said:Indeed, many of these "built-in amps" are poorly designed by people who have no clue whatsoever to what they are doing.
Sure, powered monitors have some advantages.ssscientist said:Well, Ms Hilarious, Sonic Albert and Ethan Winer, I guess we might as well put our tails between our legs and go on home.
The great TheDewd has spoken.
I was going to post another well-reasoned argument in favor of powered monitors, but since TheDewd has spoken...
I need LOUD shit, this is why I never use nearfields.Zaphod B said:I guess my definition of "underpowered" differs significantly from The Dewd's.
I am using Wharfdale 8.2A monitors as nearfields, and leave the volume level on the monitors set at the middle detent. The output signal from my Tascam 2488 will easily get those monitors loud enough for the neighbors to hear - across the street. They can play very loud, very clean.
As they are not the most expensive monitors around, I would feel certain that more respected brands would perform even better.
So, I don't know WTF TheDewd is talking about. Nor, I suspect, does he.![]()
TheDewd said:And for those who want proof, have you ever opened up cheap active nearfields and looked at the small transformers, poor design and cheap parts?
I need at least a 12'' woofer in order to get the response I need.
About 115 to 120 dB is a good level for me.
Those small nearfields top at about 100 or 110dB.
