F
Freak-a-zoid
Took some of your adivces from my first post to do as some said and study a little more.
So I thought instead of trying to find a quick remedy like duck taping a leak I'd try and learn more about what is causing the leak and properly use the right tools for the right job.
I remember back in my early days in the 80's having this peavey head that had eq knobs on it, never really understood in depth the uses of it other than using the faders until i found the sound i wanted, much like my MarkII mesa boogie head.
I bought Ozone Izotope a few months back and decided to read the manual several times to perhaps get a better understanding of the concept.
parametric eq and frequencies?
there are 8 bands, 2 shelves and 6 bands.
the ranges from 20hz to 20khz, im assuming this is the range of the human ear?
Since Ozone allows you to adjust the width of the bands, is there a standard setting with range for each band?
if so, could i get some recommedations on how I should set the band widths or does it depend on the type of music being recorded?
Then I'd like ask some opinions about frequencies.
If anyone can give me a good range to set the bands I would appreciate it..
Thanks alot for any help
