E
etnoziroh
I'll try to be as clear as I can.
I read on another post it helps to sweep a Hi pass until you hear an audible difference and backing off a little. Same goes for Low Pass. Removing inaudible frequencies for that instrument that may mud up the mix.
My question is when doing a Hi pass on the first (parameter? Channel?) which is down by the 15zh - 60hz range. Do you lower it to the lowest db (around -22db) first for total cut and then sweep up or should you leave it at 0db and sweep?
Same question for Low pass on the last hi frequency (parameter? Channel?)
Am I making any sense?
Thanks
Thanks
