Yeah, but what I'm saying is that mixing your 30:1 compressed send with the original signal 50/50 (for example) would seem to be broadly equivalent to having a 15:1 compressor insert, because your original material can be considered to have a 1:1 compressor on it. You smash half the signal, then you bring half of it back by mixing in the original - seems equivalent to only smashing it half as much in the first place.
A number of us did this or variations of it long before we knew what it was or that it was a known technique.With parallel compression, you are adding a compressed version of the instrument to the uncompressed. Mixing the two. This adds punch while keeping the dynamics of the original.
This explains it.
I use it for 2 things mainly,
Drums. I have 1 buss L+R of the drum mix going to Stereo with no compression at all (although some of the channels may have some compression beforehand i.e. snare and kick), a second L+R buss of the drum mix is going through a compressor and then to the stereo buss. By mixing the 2 you can achieve a punchy drum sound without it sounding squashed.
Vocals. I split the vocal recording to 2 channels of the mixer. I have 1 vocal channel running straight to the stereo buss with the normal eq, etc. The second vocal channel has a compressor inserted, this is compressed slightly harder (steeper ratio) than you would normally trying to act on the loud parts mostly, the compressed channel is then eq ed and I usually have the effects send going from this channel but not always depending on what I am looking for. By mixing the 2 vocal channels so that the uncompressed channel and the compressed channel are similar volume in the quiet parts and the compressed channel stays down in the loud bits with the uncompressed channel getting louder the vocal mix sits in the mix without it sounding over compressed. You have to experiment to get it right.
And sometimes I don't use parallel compression at all.
Alan.
I use it on whole mixes on occasion. KEEP IN MIND THOUGH that with most simplistic additive processes such as this that it's also a simplistic process to completely trash the whole thing. "Less" is almost universally more.So, can this be used on anything? Not just drums?
Just a case of messing around and seeing how it sounds?
Undoubtedly. Parallel compression is very rarely simply "parallel" in the sense of "same" -- I use parallel processing frequently, but almost always bandpassed somewhere, possibly shifted, often in mono, heavily bandpassed and inverted, sidechained -- It's almost never just an unaltered auxiliary.Just to jump in here, 'Boulder has touched on why parallel can be different than the same at half the ratio. The key I believe is not that it has to be the kind that does or doesn't do such and such with the peaks or what have you,. it is that it allows very different and/or heavy handed styles of comp to be used- plus eq'd if desired, and then placed where you want it in level and in ways you wouldn't do to the whole path.
We can do a mix with 2nd layer 'smashed peaks, slow attack to accentuate, various colors (color' comps or not, eq or not..
Often the frequency of EQ needs to be changed for the instrument. The vocal works well with tons of 5kHz to 8 kHz added to the "exciting compressor;" guitars work better with 3 kHz - 5 kHz and bass guitars work better with 800 hZ to 1.5 kHz.
I see. Mine' ('our's, 'there's?... But not yours?This^^^^^^^
I see a lot of really bad parallel compression overuse in yall's collective future.
