bennychico11
dmbpettit said:would an example of having something different in the left and right be just eq each differently or add reverb to one side?
well, yeah, technically that would make the two channels different now...but it wouldn't make it a stereo signal. The original source would still be mono. You've just created an effect to manipulate the mono sound coming from the two speakers. If you want a true stereo image, you need to record a stereo image.
Where is it said that two sounds can't share the same space'. It happens all the time quite naturally and as they say, 'it is what is is'. If what it is is a problem, then you scoot things around a bit.
