I am converting MIDI data to audio using the following components/settings:
- MIDI track output going through external source (keyboard)
- audio going from keyboard to Line-In on the Soundblaster Live!
My question has to do with the settings of the destination track. If I have the In field set to "Stereo", the resulting track is indeed a stereo track which sounds virtually identical to the MIDI track it was recorded from; however I cannot pan to the right. In other words if I pan full to the left on playback, the volume doesn't change in either stereo channel (the left is slightly louder to begin with) - but if I pan full to the right, the volume goes down to zero.
I can record using the left channel as the In (as opposed to stereo like above), and this allows me to pan wherever I want on playback, but the sound quality isn't quite as good - I guess that's because the sound is being forced into one channel when recording an then artifically split back into two channels for stereo effect? I'm not sure. Does my cable have anything to do with this (i.e., are there mono cables as opposed to stereo cables)?
I want the superior sound of recording in stereo without sacrificing my panning options - any advice would be appreciated.
Thanks,
Adam
Thanks,
Adam
