T
		The Lotus Kid
I have a few questions about the cover material for acoustic panels. I'll be using Roxul as the absorber behind the material.
Has anyone used felt as the material? It's breathable, but not nearly as loose-weave as burlap.
With burlap's rise to home decorating fame, felt is a lot cheaper. Is felt comparable? I am looking for the cheapest possible effective option, whatever it may be.
Also, I've been told frequencies below 500hz will pass through average window glass and frequencies above will reflect off (roughly). Is this true? And if so, if i were to make a panel out of mineral wool, and cover it with a sheet of glass instead of fabric, would the below 500's pass through into the absorber, and the above 500's reflect off?
Thanks in advance,
Matt
Thanks in advance,
Matt
