A
Antz_Marchin
Is a small 80 Watt Pa (Kustom) gonna put out at much volume as say an 80 Watt Acoustic guitar amp or is it different since it's split to two cabinets??? I'm looking to a bar/coffee house PA for a guitar and 1/2 mics. Do you think that an 80 Watt will be enough or is there a need for me to step it up to 100W for about $60 on a tight budet?? Thanks....... BJ
An excellent question: the best way is to audition each one to hear how it sounds. TAKE HEED; some amps are more EFFICIANT than others, 80 watts from a Kustom may not be as loud as a Fender or Marshall. Even within the same manufacturer there can be a major difference. The 100 watt may not be as loud as the 80watt because the 100 watt may be driving bigger speakers in the cabnet.
BJ I was not too impressed with the 100watt systems specs. No specs on the 80 watt system, although gut feeling is go with that one. Is there anywhere near your home to shop and audition a few more systems? If not, Go for this one, I hope it works for you, Are you mostly accoustic in performance?
