G
GmanJeff
New P.A. buyer has a few questions - hope you experts out there can help out with some insights!
Classic rock band getting it together enough to start playing out once in a while, very part-time (rehearse together twice a month; hope to play out maybe once every couple of months in the future); time to get a basic P.A. (powered mixer, 2 mains, 2 monitors). We anticipate small venues only, and plan only to have male vox going through the P.A. Would appreciate views about the relative sonic merits of 10" woofer-eqipped P.A. speakers vs. 12"s or 15"s. We have the same question for monitors - are smaller ones from a given brand likely to sound pretty much the same, but maybe just not play as loudly or be as well suited to running full instrumentation through them? The smaller size and weight of 10"s are appealling, although smaller speakers seem generally to be 1 to 3 db less efficient than comparable 15"s; is that a significant difference? We'll probably drive the mains with 300 watts each or so.
We're trying to keep the cost down until we know whether the band will last a while, and are considering speakers from brands like Peavey and Carvin. We're assuming that they're a worthwhile quality step up from the even more inexpensive speakers from Kustom and Nady? Not sure what to make of Behringer's speakers, which are priced similarly to low-end Peavy, and to Carvin. Behringer's 400 watt/side box mixer is appealingly inexpensive, but the brand's reputation for durability/quality is a little worrisome, so at this point we're leaning towards the Carvin PA800 series with 3 333 watt amps. Any user opinions on that product would also be welcome! We could go for the 600 watt/side Mackie or Peavy box mixers, but at this stage are not sure they're worth the significant extra cost over the lower powered comptetition. We figure that we can always upgrade later with a separate power amp for either mains or monitors; isn't it generally possible to integrate a separate amp into the circuitry of a box mixer for that purpose?
