Ozone Audio Question
  • Thread starter Thread starter gluvapor
G
gluvapor
I have the M-Audio Ozone hooked up to my laptop through my USB port - I can get Midi to work fine with reason or cubase sx. My problem comes when I use the Ozone for a line in with a guitar. I can see the signal on the Ozone but nothing in Cubase. Can anyone help? I think it may just be something obvious that i'm missing. I'm running on XP if that helps...Thanks.
You need to setup your inputs.
Click Devices at the top of the Cubase window .... Then Device setup.
Then click VST Inputs.
Thanks. I got it working. One more question about Latency..
Does it make sense that when recording and monitoring line-ins through the Ozone there's barely if any Latency - but very noticeable when using MIDI? I thought it would be an issue for both situations.
