TalismanRich
There is one other option on the newer Intel processors, called the TDP or Thermal Design Power. There is an Up and a Down setting. The TDP-Down is the lowest normal speed that the processor will be running, with the most efficient setting. (lowest power usage)
In this case, the I7-1165G7 has a TDP=Down of 1.2gHz, and draws 12 watts. The TDP=Up is 2.8gHz, and there it draws 28 watts. If you run higher than that, you begin to stress the cooling. Some manufacturers can configure the TDP-Down setting to get more processor speed at the cost of battery life. On my Lenovo, the std TDP-Down is 1.3gHz, but the manufacturer sets it at 1.5gHz. If the system is configurable, it may be found in the BIOS settings.
