nuemes
Be Here Now
Please respond only if you’ve had experience with multiple OH mics in the past. Here’s what I’ve got now:
MXL603 (2)
AKG C414uls (paid $350 used)
AT4033 (paid $300 used)
I’m recording mostly 70’s rock & occasional jazz. I want a natural, non-hyped sound yet at the same time I’m typically recording low budget, poorly tuned drum kits so I’m not sure if a natural sounding mic is really the right answer at this time.
For rock I mic the snare (SM57/i5), kick (ATM25) and toms (SM57’s) and have been using the MXL603’s as overheads. When mixing I cut the lows out of the OH’s and use them mainly for the cymbal sound and to get some high end from the toms. The preamps are Digi 002’s for the OH’s.
The room is small: 7x8 with 7ft ceiling and is as dead as I can get it (carpeted walls with some diffusion).
I ran a couple mono room mic tests in front of the kit last night with the mics I have through an Avalon M5:
MXL603: Brightest of the mics by far. Extremely hyped high-end; kind of washy. Sounds almost out of control compared to the other mics; not well defined. Very little body (mids/bass). Does nothing good for the snare.
AT4033: Somewhat hyped high-end but not nearly so much as the MXL603. Good snare and tom sound, good overall room sound, less low end/fullness than the C414uls. Kind of boxy sounding but in a good way; has a 70’s FM radio vibe to it. More focused than the MXL603.
AKG C414uls: Sounds much darker than the MXL603 & AT4033 (due to the fact that they’re both hyped); the most neutral of the 3 mics. Easily the best overall room mic; picks everything up well. The most focused sounding; best bass and mids; great snare and toms. Cymbals sound boring on the AKG compared to the other 2 mics.
A second listener liked the MXL603 and AT4033 best. I liked the AT4033 best because it was brighter than the C414 but not as out-of-control hyped as the MXL603. As I don’t have good outboard EQ it might be better to get brightness from the AT4033 rather than adding EQ to the C414 through software EQ.
So here’s what I’m thinking: pick up another AT4033 for $300 used and use them at the overheads, or pick up a stereo pair of some other mic that would run no more than $400 used, assuming there’s a better option than the AT4033 in that price range. I’ve heard good things about the Shure SM81 & ATM450 which both fit my budget but have not heard them; not sure if they would be an improvement over to AT4033.
What would you do given the mics on hand/budget?
MXL603 (2)
