outboard effects
  • Thread starter Thread starter StudioMxpx
StudioMxpx
im using the delta 44, i dont have any out board effects yet but i was wondering since the effects are going out of the sound card hows it posible for the effects to work...im confused or is it like a guitar pedal...example guitar to preamp to compressor to the delta... im a newbie i just wanted to know.
Yeah .... if you are wanting to use the effect on the way in, it would go in between the preamp and the input of the 44. Also some preamps offer insert points that can be used for routing in effects.
Another method would be to record the instrument/vocal dry (with no effects) then assign that track to one of the 44's outputs, which would then go thru the external effect and back in to one of the 44's inputs and recorded as a new track. Although, this method creates additional D/A and A/D conversion and can run the risk of track offset due to latency (unless your program automatically offsets for recording latency).
If it's an effect you know you want and are content with it's sound .... no reason to not just use it on the way in. The only drawback is that it's printed that way and there's no turning back without a retake.
Wabatuckian
Replies
9
Views
832
Wabatuckian
Wabatuckian
T
Replies
4
Views
537
TalismanRich
TalismanRich
C
Replies
23
Views
4K
Old Music Guy
Old Music Guy
