thereelman77
Hi their.
Recently I posted regarding my teac 80-8 calibration, a journey that was completed successfully.
Now I'm onto my 2 track.
I'm attempting to calibrate Record Equalization on the deck and following the manual, I'm running into an issue:
The manual simply states "connect the audio oscillator to the INPUT of the recorder". Now, the problem is that, the known set up of the Otari decks is that they were wired pin-2 hot or pin-3 hot or whatever, so I re-soldered the MIC INPUT back when I got it, to whatever the modern standards are (the opposite of what I stated previously) so that the XLR cables would receive a good signal.
Can I use the MIC INPUT to calibrate the deck or do I have to re-solder the INPUT as well? Because the issue is that the MIC INPUT has a an Attenuator switch for 0db, -20db, & Off and I'm not sure where to set it. When it is on OFF= I get the same level input signal as I did from the input, even with the INPUT knobs cranked. When it is in -20db/0db= I get a much hotter signal, registering on the VU's, but also a noise increase.
Thoughts?
Thoughts?
