D
denniswang
oPetrol oxy-gasoline torches use ordinary liquid gasoline for steel cutting.
Safe and saves up to 90% on fuel cost.
Gasoline is available in every gas station.
Dealers search worldwide.
oPetrol
oPetrol vs Petrogen
1. the gasoline is atomized at the oPetrol tip, and vaporized at the Petrogen tip. OPetrol is a new generation of oxy-gasoline cutting technology. There is no smoke, nor dripping of gasoline during oPetrol¡¯s ignition and operation. Less pollution and more fuel saving.
2, the oPetrol gasoline tank is specially designed and filled in with military explosion-repressig material. The tank is safe even the operator light a fire at its gasoline filling mouth when the tank is full of gasoline.
3. the oPetrol gasoline tank is made for a constant fueling pressure. It needs to be pumped only once each time refilling the gasoline. Once filled and pumped to the required pressure, the whole tank of gasoline can be used.
4. oPetrol can be used for welding and brazing.
http://www.opetrol.com
oPetrol
oPetrol vs Petrogen
