Glad to be of ser-vice
How is your room treated?
Sadly, it's not...I live in an apartment with a big glass door that leads to a busy street in downtown Toronto
Most of the things I record are direct, though - the bass and guitar are direct input, the keyboard is done via midi, and I hauled my stuff to a recording studio for the drums. The vocals are recorded with a mic in my apartment, but she's just singing directly into an SM57.
How much do you know about "Subtracive EQ" (google and experiment!)
Not as much as I should! Since I'm a bassist, I was able to EQ the bass guitar - I mostly cut a lot of stuff below 100Hz and then tried shaping the frequencies between 125 and 630. It would probably help the vocals to be able to EQ them as well, but I have no idea what I'm doing. I will however take your suggestion to google it and maybe even play around with some presets.
Something is wrong with your panning, the mix is lopsided. You need to figure out why that's happening and re-mix your tune. Something in your chain is funky, if your not hearing how unbalanced it is. Maybe get someone to help you go through your system and make sure everything is panning and monitoring exactly right. Its very important that what you create in your studio translates correctly to the outside listener(s).
I copied the file over to my ipod, and the panning is definitely lopsided. I think I'll need to uninstall and reinstall the drivers for my M-Audio device because I don't hear any separation either within Cubase or when I play back the file.
Love the song, reminds me a little of Jefferson Airplane.
Thanks much!
I'd like to hear the bass really hit the beat on the transitions between sections. I feel you are missing the accents and a little bit of the swing on what is otherwise an almost perfectly composed bass part. If you can re-track this bass with a real focus on swing and leading the band and defining the transitions using accents then you are getting closer. It's a killer little tune.
That's an interesting point, I'll see what I can do. I might make the transitions follow the syncopation a bit more.
I'll also speak to the vocal cut --- The singer is a little bit timid so you can hear where she's holding back and being cautious. This affects her tone but also the delivery of the lines - it loses the drama of the vocal. Some of this might come from the fact that the swing of the song is slightly lacking so she doesn't have a real anchor the dig into and get in the pocket or it could just be nerves. On my vocals I've been tracking in my condo so I bring that same timidity to the table and can hear it in my own mixes. With a re-recorded bass track, and a little direction while she cuts the track I think you could get a better vocal performance from her. Especially again on the transitions where she opens and closes a section. Missing a few vocal opportunities there to really nail the drama.
I think I might get her to redo it, yes. After listening to the takes, I realized that I should have been a bit more fussy.
At .40 --- .46 I would rewrite the bass part - your singer is kinda naked here and the chordal transitions are not well defined and supporting her. My ear is searching for a bass that is sliding up and down into chord & note figures here.
The chords in that section were take from Bach - blame him!
Lyrics: the repetition of that same phrase "there's only so much time in the world" -- do you have another line that you could work there as well -- can you open up the lyric more? My thoughts are that this song could be another minute long provided we opened up that verse a little more lyrically. Can you post the lyrics and structure as is for us to see?
Yeah, I was kind of unsure about that, thanks for bringing that up. I'll have to mull it over and see if there's another good phrase that fits the same rhythm.
Thanks for the suggestions, everybody! I'll do some troubleshooting with the panning and see what I come up with.
