funckyfinger said:
Somehow the idea of doing single mic bluegrass style recordings has infected me. I can't help but think that compression would be a huge help.
Are you basing that thought on actual trails of recording w/o compression, or on an educated hunch by thinking about it before-hand?
If you're talking a bluegrass band, something like a 4-piece (fiddle, banjo, guitar and bass) along with 2- to 4-part harmony vocals, you might want to consider trying it first w/o compression just to see what you get first. It may not work, but it'll give you an idea of where you're coming form so you know what you have to do to get you where you want to go.
Experienced bluegrass bands should be pretty used to working showcase parts live with only one or two mics. As such they often have a physical technique of knowing how to share the mic for vocals and how to actually shift their positions to put the showcase instrument nearest the microphone during the couple of lines while that instrument is featured. It's like a version of working the mic on a grand scale, and it tends to self-compress the presentation somewhat.
Add to that the typical bluegrass song arrangement of a rather dense combination of string finger picking, even-tempered strumming, and bowing, with the vocals riding over that, and you should have a somewhat natural mix of interesting dynamics within a fairly tame overall envelope. I don't envision there being a whole lot of wild peaks to have to tame (though I make no guarantees
.) I'd think that the first concern would be to keep the vocals in line and to make sure they don't trampoline too hard on the instruments.
As such, if compression is actually needed, I might look at one of two extremes just to see what they do, and improv from there. First I'd try a light compression (<2:1) at a medium threshold, somwhere around the RMS level, say, just to glue the upper half of the dynamics a bit. Second is I might try leaving the internal dynamics pretty much alone (the idea of compressing finger pickin banjo just does not thrill me), but throw some soft-knee medium compression (2:1 - 3:1 or so) at a higher threshold that just grabs the loudest vocals and keeps them from getting away.
This is all guess, as I personally would not want to track bluegrass without at least 2 or 3 mics myself (one vocal mic minimum, one lower or seperate instrument mic minimum for banjo and guitar, and optionally one OH mic pointing down at the fiddle.)
G.
