P
polarity
When doing the stereo mic'ing. I'm trying moving it around abit 12 fret and 90 degrees and then bridge and 45 degrees or so but I'm definately getting way more signal from the back mic, which does seem to make it sound a little more natural, but the signal is so low I'm hearing alot more of the room. I've got the one at the 12th around 6" off the neck and the one at the bridge around 8" I've tried changing the angles but I end up with alot more low end (which I guess I could try and EQ out).
Just curious what others are doing, if you're using different gain for the 2 mics or matching, etc.
thanks
thanks
