Dags
Hi everyone and welcome to 2013.
Got a [edit: couple of] question for the electronics/electrical/tech gurus out there.
I sat in on a recording session for creating SFX and the technician had one phantom-powered shotgun mic connected to his portable recorder by a Y-cable to allow the same signal to pass to two preamps and recording channels set at different levels so that if the louder channel clips, the softer one maintains the peak of the waveform which can be edited in later.
What did my head in was that the unit supplied phantom power across all channels, so presumably the mic was seeing phantom power from both preamp channels and it didn't blow up the mic or damage the portable recorder.
He's been using that technique for years.
My first question is, how does the mic handle multiple phantom power sources in this way? Is it because it is connected to a single unit sending phantom power on all channels simultaneously that it somehow addresses any power feedback issues?
My second question is, is this power handling something that is unique to shotgun mics or could studio condenser mics also be used with a Y-cable connected to two preamps, and if so, would you only need to supply phantom on one channel or both to get a signal to each preamp?
If anyone is able to shed some light on this technical mystery and let me know if it is *safe* to attempt this at home that would be awesome.
......anyone game enough to try this with one of their condenser mics & a couple of preamps and let me know the outcome?
Dags
Dags
