Pretty nice effort. I don't remember hearing the first version, so I can't compare. I loved that little electric rhythm guit hitting the backbeats. Had a perfect tone for the part.
I'd say the piano and acoustic guit are a little out of balance, with the piano being a bit too dominant and the acoustic not being prominent enough. Maybe pull the piano level back a bit and boost the guit?
Little pitchiness at :39-:40. Some vocals get a little buried (e.g., at 1:07 the piano chord covers the vocal).
Could probably make the lead guit just a little brighter. Try a small EQ boost of everything above 5500hz or so. See what it sounds like.
Not sure how far away you were from the mic when you tracked the vox. If applicable, I might recommend getting an inch or two closer.
Just thoughts of things you might want to try... Trip.
