X
xstatic
There is nothing wrong with using a little EQ, compression or whatever while you are tracking if you know what you are doing. Those decisions are no harder for the qualified engineer than picking the right amp, guitar, mic, placement etc... Sometimes though you do make a bad decision, but this is just as likely to happen somewhere else in the signal chain as well. If however you are using a comp for peak control, then I would say you have an issue, but that has to do with gain structure and not with decision making. The good engineers, be it tracking, mixing or mastering are generally hired for what they do, not for what they were too afraid to do. The way I see it, if you can't make SOME sort of commitment at the get go, then you have other things that are out of order as well
