On a 421, remove the metal plate near the XLR connector, and take the screw underneath out. The XLR connector assembly pops out. If you look inside, you see a glob of silicone inside the end of the cavity. If you cut that glob away, you'll find a 7mm bolt, which, when removed, lets the mike come apart.
