oboe_prestini
Good day from Belgium. I have been roaming the web for advice on the best way to record chamber music on location. This is not for professional activities, so I am on a limited budget. The classic combination of a mixer + direct stereo recording on DAT equipment seems out. Probably one could use direct recording onto CD (e.g. TASCAM 750), but I am not sure about the reliability of this method. Editing is limited to the two stereo tracks anyway. So I took a look at the DAW's that are geared towards pop & rock music. Most of these (at least the cheaper versions) have only 2 phantom powered XLR mic inputs. Probably I would stick to that initially (violin + piano, small chamber orchestra), but suppose I want to use four mics to record every member of a string quartet, then I need to look at DAW's with more than 2 XLR inputs. Choices, again in the budget line, are limited to BOSS BR1600, and KORG 1600MkII. The latter has 24bit recording, and is recommended. Again, I would not make much use of all built-in effects considering the type of music I would like to record. Post-record processing would be limited to balancing and reverb at the most. Any advice/experience is gratefully acknowledged. Regards.
