for time based effects, use your sends on the channel....except assign it an output instead of a bus.
patch out of the assigned output, into the effects unit, then back into a valid input (probably stereo). Then either create an aux track and set it's input to where the effect is coming back in at...or create an audio track and just record the effect once you have it down.
