M
mncheetah
Can someone put up a diagram of how a double wall observation window should look. Do both sides of both walls have to be sheet rocked, if so - how do you get in and sheetrock between the two walls - there would be no room. Would the STC rating be comperable for a single 2x8 wall with staggered 2x4 studs. Also, how are the glass plates mounted - please describe the framing process. Thank you.
