Son of Mixerman
Mix Junior
Well, the first things I wold do is take the tape to a audio restoration place and have the original tape put in the kind of condition it need before I load anything on a R2R so Im not looking at money stuck to the Repro head on my recorder. If the resoration goes well Id transfer it all to hardisk using really high end converters 24/192 khz, Possibly the http://www.lavryengineering.com/ type. Id record everything right out of the recorder and not use the console. You don't want to make alot of passes on old tape. Then I'd start looking at errors, clicks and pops that can be repaired using denoise or Cedar retouch type of restoration plugs. Depending on the shape of the original tape, you might have lost some hf definition. Ive done mastering for audio cassettes before. Its a compromise most often than not, Im not set up for it anymore though. To make it compete with todays Pop releases would be a total destruction of the audio. You would like to make it sound better with a touch of vintage. The type of tools wuld vary depending on the type of music. Beatles music for the most parts isn't crushed like todays so you'll have lots of dynamic range to play with. I definitely would use the Weiss Eq-1Mk2(Cranesong Ibis maybe), a Cranesong Hedd, Manley Vari-Mu compressor or maybe a Maslec MLA-2....
I would use a Bryston amp and some nice Dunlavy monitors...
As far as applying the equipment to the problem is pure fantasy until the 2 meet.
SoMm
SoMm
