Hello everyone!
I have a rather annoying problem.
Yesterday I recieved my new SM7b. It although did not really work out the way I wanted it to. There is a quite strong noise all the way from 4-5kHz up to 10-20kHz.
At first I thought it was a preamp issue. I've tried three different preamps (Line Audio 2MP, built-in Mbox 2 PRO and some cheap Begringer thing) coming up with the same result though. I have also tried to connect the preamps to each other (so that each individual preamp need to use much less gain) and the noise was just the same.
For quite speech at a distance of about 40cm from the mic the noise level was around -30db when you elevated the speech peaks to 0. For louder speech and yelling at a distance of about 35cm from the mic the noise level was around -40db when you elevated it so that the peaks were around 0. It is still TOO much. As far as you start compressing or equalizing it sounds like a computer mic.
I have also checked and rechecked that the there are no high frequency noices inside of the recording room.
The board are not allowing me to url to clips if I don¨t post more than 5 posts. Exept that I have plenty of clips to show you if you are interested.
What do you think the problem might be? Was the microphone simply broken when delivered? Are the preamps just bad?
Thanks
Thanks
