What is the easiest way to put a noise gate on 3 mic inputs of a VS1680. I use the 2 XLR inputs for SM57 used to mic 2 Marshall in stereo. The 3rd mic is a Neumann TL103 through tube preamp + compression.
The problem is that the Marshalls have noise, and the Neumann picks up even steps of my cats 30 feet away.
So far, I've only been able to use the build-in noise gate by inserting it in one of the mic lines, but then the effect is no longer available, since I'm not using the effect send/return but in-line.
Does this mean that I need to purchase an outside multi-channel noise gate?
If yes, how would I get the inputs back into the mixing board? Also, wouldn't I lose the mic pre-amps if I did that?
Help...
Help...
