G
g_cream
Hello People:
I Have a lot of time trying to record from the vst instruments, i'm getting crazy! Every night, when i come back from working, i sit down for hours in my computer trying to solve this...
I've read the manual, i completely know the procedure to play and record the vst instruments, and i've done it like a thousand times, but it still doesn't work.
I load the instrument, (specifically the LM7 im trying to use) Connect the In to "All Midi Imputs", The Out to "LM7", i turned on the monitor button and record enable, and there is no VU level when i play the drum, i can hear it because is turned on, but the midi track doesn't look like is getting any signal from the instrument, THE VU LEVEL DOESN'T MOVE!, and of course if i try to record, it makes the rectangle like it's recording but when i stop it, the rectangle dissapears, and doesn't record anything.
I've checked the preferences and all seems to be fine, i almost memorized the manual about this, and i can't find what's the problem with this.
One time i remember i was frenetic trying to make it sound and punchin' a lot of keys and the VU meter of the midi track (I think) it moved a little bit, but i've tryed that so much, that at this time i think it was just an illusion, and it doesn't move really.
If anyone of you can tell me exactly what u regularity do to play a vst instrument, or if any of you have the pacience to explain me step by step what to do, i will aprecciate from the botton of my heart...
