No sound coming out from cubase !
  • Thread starter Thread starter lukicore
L
lukicore
Member
Ok it is been a while i did not use my studio and right now i have this problem ! Every other software i use is working good i have sound but when i want to play my projects recorden in cubase i dont have sound I can see that there is a signal but no sound
Where exactly i can fix this
Please help me !!
Hey, lukicore.
Hope you're doing well!
We'll need a little bit more information. What version of Cubase are you using? Did you somehow mess with the outputs or the control panel? Are the tracks engaged (to be recorded)?
Likely, you have lost connection with whatever you are using for audio interface.
Explain what you are using. May be as simple as selecting your interface within Cubase Device Setup Panel.
im using old cubase 3 little presonus firebox What else hmmmm... ?
But i thing you already answer my question i will check thit tomorrow after work Thanx boys :-) I apreciate
Check your setup in this order:
1) Your interface's driver in the Device Setup
2) VST Connections (F4)
3) the output routing in your track's inspector
