SonicAlbert
Super-Sonic "Herb" Albert
Not a lot of opining for me to do, just want to point out a couple things.
You should measure the actual noise floor of your studio. You might be surprised.
I have a Behringer DEQ2496, actually a great piece of gear when it comes to metering and RTA. In the RTA or metering mode it is very easy for me to see what the noise floor of my studio is. It sounds so quiet, but is not as quiet as I would have thought! Needless to say, it's not -120!
So could you actually hear the difference between a noise floor of -110 and -120? I *seriously* doubt it. The natural hiss of an analog mixer will be much louder than that. One thing I have to give digital is that it is *quiet*. There was a noticable drop in the noise floor when I went to the DM-24's from my analog mixers.
So debating -110 versus -120 seems a little academic to me, knowing that you will most likely be operating in a real world SN ratio of probably around -80 or so (if you get things really clean and quiet). It looks like 10 dB more of headroom on paper, but it really isn't, in my opinion.
That said, there's a lot more to making a converter sound good than the SN specs. So I would suspect that the MOTU 896HD would still be a nice upgrade for you and be quite useful. Ideally, if you are mixing analog, you'll want 16-24 channels of DA conversion from the DAW to the board. Not sure exactly how many channels are possible with the MOTU unit you are considering, if it is more than eight.
This is the real consideration when deciding whether to go with an analog board or digital: the number and quality of converters you have available to you. It's a balancing act. If you don't have good converters, and I mean really good converters, then you lose more with the DA conversion than you gain with the analog mixer. Detail, naturalness, that sort of thing. In that scenario it is better to stay digital in my opinion, as you don't lose anything.
On the other hand, if you have enough great converters, then it's viable to go with an analog board. Since there is little or no quality loss with the DA conversion, you get the advantages of analog mixing.
The thing is, 16-24 channels of *really good* conversion is not cheap. This was a major consideration for me in my own choice of going with digital boards. I record using a really nice two channel preamp through a really nice converter, and once digital it stays there. That's mostly recording acoustic instruments like piano. My synths I record through the DM-24's, or straight to digital if they have digital outputs. Up to this point, I've chosen not to invest in a large number of outboard DA converters.
As far as integrating an analog mixer to a DAW versus a digital mixer, it's not that different really. It's just with one you need great DA converters galor and the other you need the connections made through a digital interface like the MOTU 2408 for example. The routing from the computer will feel virtually the same, as you will just be selecting outputs for the signals.
More food for thought!
