I
Ibrow
My first post so go easy on me.
Here's what I want to do and what I have.
I want to take a CD track, ex. White Christmas from Bing Crosby, turn it into a WAV file. I have done that with Plextor Track Extractor. Next, I want to eliminate or reduce Bing's singing voice. I have tried with Cool Edit 2000 but I can't get rid of it. From what I've read on the boards here, it's impossible. But is there software out there that allows you to use that "karaoke" effect? You know how some systems allow you to hook up a microphone to your stereo system, press the "karaoke" button, then you can sing over the speakers because the cd track's voice is muted somewhat. Does anyone know of any software that will do this for me? I can't believe Cool Edit didn't have this option.
Secondly, I want to take that "voiced down" WAV file and record me singing over it. If I had to burn just that track to CDR and play it from another CD source over headphones so I can sing would be fine. My question is what should I do to record, micwise? I can record with my computer mike using CE2000. It sounds pretty bad, but it'll work. Do I really need to get a microphone to hook into my sound card, or will the computer mic suffice? I can peruse the Microphone Section if I really have to. I have already done a lot of reading on the subject and long run I'll have to get a Mic and an "amp" of some sort to bring the mic to line level I guess. Suggestions?
Finally, (Christ this is long.
) I will have to mix my recorded voice down with the voiced down WAV file. I think I have Vegas Pro 1.0. The only time I used it I had a huge HISS over the entire mixed down track. Does anyone know what caused that? My guesses are I left the Microphone plugged in while mixing down, or I have a shitty soundcard. I don't even know what soundcard I have. It's the one that came with my computer. I really doubt it's the software. Suggestions?
Any help you all can give an absolute newbie would be appreciated. And if you could, please be like Denzel in "Philadelphia", and ,"Explain it to me like I'm a two-year old."
Thanks,
Ibrow
Thanks,
Ibrow
