M
MoBuc
Hi all,
I have the Tascam US-1800 USB Audio Interface. I've recently discovered the driver for this device does not route playback into a PC recording program if the "playing" program is also, on the same PC. I am assuming the exception is playing a track within an "In-Box" DAW can record back to a new Track (Mix Down) within the same Software. (Cubase may allow route back into itself. I'm new to Cubase.
Q: How may I play audio in 1 program & record it into Audacity (or Cubase LE5)? Ideally, I want to have only 1 Audio Driver enabled. I would like to hear connectivity ideas for 2 Audio Cards, if that is the only work-around available. That's how I have been doing it up till now.
Old Way :
US1800: Enabled w/ USB to PC, I/O & COAX SPDIF to EMU 1212m
EMU 1212m: Enabled w/ I/O Spdif Coax to same of US1800.
WinXP Onbord Crd: BIOS disabled, & Wavetable Disabled
Ideal:
US1800: Enabled w/USB to PC & I/O & COAX to misc External Devices/Instruments
EMU 1212m: Disabled & unused
WinXP Onboard Crd: Disabled & unused.
I'm open for suggestions. The "Old Way" is very awkward & time consuming to configure as it is different for each PC Program pairs involved (WMP to Audacity, Internet Browser to Audacity or DAWs, etc.).
Thanks in advance for your ideas.
)Q: How may I play audio in 1 program & record it into Audacity (or Cubase LE5)? Ideally, I want to have only 1 Audio Driver enabled. I would like to hear connectivity ideas for 2 Audio Cards, if that is the only work-around available. That's how I have been doing it up till now.
Old Way :US1800: Enabled w/ USB to PC, I/O & COAX SPDIF to EMU 1212m
Ideal:US1800: Enabled w/USB to PC & I/O & COAX to misc External Devices/Instruments
