Newbie question about interfaces
  • Thread starter Thread starter the_man
T
the_man
Yo,
Currently, I'm recording into the line in of my soundcard. It's not a fancy card, its whatever came with my computer. It's only 16 bit.
If I wanted to record at 24 bit, I know I could get a better soundcard, but I was wondering about the interface itself. If I got one of those USB interfaces, would my signal still pass through the soundcard on the way to the hard drive? Obviously, anything I hear out the spreakers has been processed by the soundcard, but when recording, can I bypass the soundcard entirely by using an outboard interface?
THanks,
Kevin
the_man said:
Yo,
THanks,
Kevin
The soundcard is what converts the analog audio into digital information. USB audio interfaces are still sound cards...
Re: Re: Newbie question about interfaces
Hmmm, so interfaces *are* soundcards? Why are they called "interfaces" instead of...wait for it..."soundcards".
That would have saved me a lot of confusion.
I won't have any trouble recording from a USB or PCI port with n-track, will I?
Kevin
No. It would be an independent audio data stream.
Obviously, anything I hear out the spreakers has been processed by the soundcard...
Well, you could connect the speakers to a USB audio device just as well, and route the output of your software to it instead of your exiting sound card.
...but when recording, can I bypass the soundcard entirely by using an outboard interface?
You can bypass both recording and playing through it in favor of the USB device.
Sweet!! That's what I wanted to hear. Final question: the bandwidth issues associated with USB shouldn't affect me if I'm only recording from one channel at a time, right?
It depends on how many tracks you plan to record at a time. USB can barely handle 4 tracks of 24bit audio at a time.
The bigger issue is that USB soundcards are notorious for incompatability problems.
What it really comes down to is $$. You are paying a premium for a USB device over a PCI card and getting inferior performance. If you don't absolutely need a USB audio interface (i.e. working on a laptop), you would be better off getting a PCI card.
Example:
Audiophile - $149
USB Audiophile - $199
