ThePhoenix said:
Hey there!
What is the difference between a mixer and a powered mixer? the powered mixers are for PAs right? can you use either one when recording? I was looking at somnething along these
lines . would this work for recording? also is it a bad brand of mixer?
thanks
A powered mixer has built-in amplifiers for driving speakers. A non-powered mixer does not. Powered mixers are generally used as practice PAs in live scenarios. Non-powered mixers are generally used for everything else from practice PAs (with seperate amps) to recording consoles.
You could theoretically use either for recording, it has been done.
That mixer's basic functions would technically "work," yes.
A bad brand?
Umm...no, I don't think Peavey is a bad brand...but I think most of those mixers in the $129 and under range are cheap Chinese turds.
If this is anything more than a hobby for you, throw budgetary concerns out the window, as you will exceed them at every turn. Scrape together every penny you can find, then save up another 10%. Now buy the biggest, highest-tech mixer you can afford.
Believe me, as a former Guitar Center Corporate employee, I can assure you that most of those products in the under $250 range are entirely shite, designed and built for one purpose:
separating you from your money.
they all have at least a 50% profit margin on them for GC or MF or wherever you're buying.
