azrider said:do i need a amp to run them
cpl_crud said:Techincally, that's not entirely true.
The Active/Passive definition refers to where the crossover occurs, not where the amp is. However, it's highly unlikely that a speaker that has an active crossover will be driven by an external amp (although it can happen) so the term "Active" has been adopted for "powered" speakers.
Just a bit of symantics for y'all
blazingstrings said:Yeah but now-a-dayz when you hear active it meansor refers to powered monitors.
-Blaze
pingu said:Your probably be better off spending that money on the best set of headphones you can afford.
Then after that id save up for either a set of Event ASP8 which are awesome speakers.
Around 1800 US.
Look into acoustic treatment and youl be laughing.
Probably not what you want to hear but if you get cheap speakers basically every mixing decicsion you make on them will be wrong.
If you want top results you need to consider
better preamps and ad conversion
better speakers and acoustic treatment.
Then focus on tracking to perfection.
Trust me and focus on these aspects as soon as you can and you will get to your goals a lot sooner.
