I bought Cubasis VST 2.0 some time ago at a local shop and it seems a lot more complicated than they alluded to. I am not being successful at recording or hearing anything. Are there any easy tutorials about to be read or attended? I feel that I can grasp it with some help but starting is seemingly impossible. This is not easy at all. HELP!!!!!!!!!!!!
just experiment with everything... use the HTML help feature (located in the "help" menu), and read the manual. The best way to learn is by doing though, so just experiment with everything, look through every pulldown menu, click and right click on stuff, just mess around. Try dragging an audio file from your computer into a project, and try to cut it up and mess w/ it. if you right click on the bar on the left of the screen that and select "create new track", that will create a new channel in the main window where you can drag and drop that piece of audio. Scissors are self explanatory, go to work
