N
nikster
I need some help hooking up my Shure PE15H Dynamic Mic to my Soundcard on my PC which is a SBLive. I'm looking into recording some vocals and guitar to my PC so I can hear myself and see what I need to work on.
I went to one of the local retailers here and explained what I wanted to do to one of the salesmen. He suggested I get a MM1002 Phonic Compact Mixer. It was only 50 dollars which was all I can spend at the moment. I had told him I wanted one of those small 50 dollar phantom power mic preamps, but he suggested I needed this, and being very new to this I went along. Since the mixer has 2 mic pre-amps, it seems it would do the job. Here is a picture of the Mixer -
http://www.phonic.com/product/mixers/mm1002/mm1002_front.jpg
Now the problem I am having is hooking up the Mic + the mixer to the SBLive. I'm connecting the mic to the XLR connector in the first slot. Now from the Main L&R I use the Y-adapter I have, all the ends are a quater 1/4th inch. Out from the Main L&R I connect it to an adapter which converts it to a single 1/8th and plug it into the Line in on the SBLive. I'm using the cheap Sound Recorder that comes with Windows just to test it out and I'm still not getting any sound from my Mic.
I don't know what the problem is, and if anyone can shed some light on what they think I'm doing wrong it would be most appreciated. From what the manual suggests I turn the mic/line lever to Mic and turn the phantom power switch on, and it should work. When I turn my mic on, still nothing comes out. My speakers are hooked up correctly to my system and work fine, and I have the Line-in under the SbLive controls checked on - I use a WinTV card which uses the line-in all the time and it works fine.
If there is any other information you need to know about my setup just let me know - thanks.
